Super neat trick for pulling off late model taillamps - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2011, 06:52 PM
I saw a guy doing this today and it just blew me away. On many later model cars and trucks (Chevy being one) the tail lamps have a pin that goes into a clip on the quarter panel. As you can see in the photo of the back side.
The light goes straight into the back of the car clipping in and then a couple of screws hold it. But honestly, those clips are VERY strong. It is very common to break the light pulling it off.
So check out this trick, you put duct tape on to the light using it as a handle being you can't grab it anywhere! BRILLIANT!
ID:	55407   Click image for larger version
ID:	55408   Click image for larger version
Old 05-18-2011, 07:22 PM
Freaken-A man. Never thought of that.
Old 05-18-2011, 07:40 PM
NEW INTERIORS's Avatar
Set no limit's on yourself
Very cool !!! GOOD OLD DUCT TAPE !!!!
Old 05-18-2011, 08:06 PM
LATECH's Avatar
Last journal entry: New Gas Tank
Wow, great Idea. I used to use cellophane tape to seperate window tint from the backing material , but this trick is too cool.
Maybe a good post should be how many ways can you use duct tape.
Just dont do any RED GREEN show tricks with it.
Old 05-18-2011, 10:04 PM
put up or shut up
Oh yeah, I've done that before. It's been a while since I've done production but I think it's necessary on the nissan 350's or maybe the infiniti that looks like one??? It's almost impossible to get it off without duct tape unless you want to break it cause the tail light is pointy
Old 05-18-2011, 10:23 PM
ogre's Avatar
the 'Duracell Project'
next martinsr will find a use for that new fangled baling twine...
Old 05-19-2011, 10:27 AM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Ironic how duct tape is good for everything except ducts.
It should never be used on ductwork.
You rock Brian, keep the tips coming!
Old 05-22-2011, 07:25 AM
deadbodyman's Avatar
Wiki Edits: 11
Gorilla glue has come out with a new duct tape its supposed to be the strongest tape on the planet,10.00 a roll....I wonder if my mentor, Red Green has used it yet???
Old 05-22-2011, 11:24 PM
put up or shut up
a little off topic question for Brian
Brian, I know you know a lot of tips in production so I was wondering if a spray on adhesion promoter would work for prepping plastic emblems for double sided tape? I've never tried it like that and have always been at shops that have the 3m wipes. Don't want to buy a whole box for this. And advice appreciated.
Old 05-22-2011, 11:38 PM
First off, honestly, you replace the emblems. I have never had an insurance company give any lip on replacing tape on emblems. Even the cheapest cut throat insurance companies don't say a single word. I replace emblems that sell for over a hundred dollars without so much as a word from them.
Just recently had to buy a complete kit for an Acura (gold plated) for $150 just to replace the two on a deck lid, they didn't say a thing.
So first off, replace them and don't go thru the hassle of re-taping.
But if you do, the 3M adhesion promotor wipes are the cats meow! We use it all the time for two sided tape components that we are re-using.
I have never used a spray on so I couldn't tell you how it well it works.
Old 05-22-2011, 11:41 PM
put up or shut up
yeah, I'm not really an insurance company so there won't be any buying it if I have a roll of double sided tape.
Trick Flow super 23 heads for 383 elcaminodragster Engine 10 08-30-2009 12:59 PM
early model vs. late model 350 blocks quincysmith Engine 11 08-15-2007 11:12 AM
Late model GM Steering Column for Model A Woody31coupe Suspension - Brakes - Steering 3 12-31-2005 05:55 AM
Late model 350 SBC Question Smoker113 Engine 3 02-19-2005 10:12 PM
Late model 5.3 SBC, what can be done? 70bird Engine 9 06-11-2004 09:30 PM
