Super Red Ram Engine - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-19-2013, 04:48 PM
I have a 1956 Dodge Custom Royal with a Super Red Ram engine. My mechanic thinks it is a Hemi, but we don't know for sure. It is all original, but we believe that we need to put new Push Rods and probably new Lifters in the motor as the lifters are noisy.
A number of years back, I purchased this car and drove it 997 miles home with no problems. The lifters were noisy then.
I now want to sell this car, but I want to make it quite.
It is all original and the interior is in beautiful condition for this old.
Can someone tell me how I get the engine size so tht I can order the parts from Egge.
Thanks In Advance
Matt
Old 09-19-2013, 05:09 PM
Banned
Dodge's Hemi, introduced in 1953 as the Red Ram.[4]
241
Dodge introduced the 241 cu in (3.9 L) engine in 1953.[4] Bore was 3.4375inches and stroke was 3.25inches. With a low compression ratio of 7.1:1, the 241 produced 140 bhp (104 kW). This engine is not the same as the Plymouth 241, which had polyspherical, not hemi heads.
270
The 270 displaced 268 cu in (4.4 L) and was used in the 1955 and 1956 Dodge high-line (premium) vehicles. Bore was 3.625 in (92.1 mm) and stroke was 3.25 in (82.6 mm). It was not the same as the Plymouth 270 poly-head. In the Dodge Coronet, running the same low 7.1:1 compression ratio as the 241, the 270 produced 140 bhp (104 kW). In higher trims like the Dodge Meadowbrook, it ran a 7.5:1 compression ratio and produced 150 bhp (112 kW).
315
For 1956, Dodge increased the displacement to 315 cu in (5.2 L) with a longer 3.80 in (96.5 mm) stroke and a taller raised-deck block and now with a polyspherical heads—no longer a Hemi. But the optional high-performance D-500 version of this engine had a four-barrel carburetor and a larger valved Dodge hemisherical combustion chambered head. Also, a "race only" package called the D-500-1 or DASH 1 was available with a special aluminum dual four barrel intake that sported a pair of Carter WCFB caburetors similar to the ones on the Chrysler 300B and DeSoto Adventurer. This engine utilized the same cylinders heads as the base D-500 model.
also get the numbers off of the block and use this link
http://www.hothemiheads.com/hemi_inf...engine_id.html
Faith - Respect - Trust
First of all, if your mechanic can't figure out if the car's engine is a Hemi or not...no to offend but, every mechanic should know what Hemi is. The easiest way to tell is if the spark plugs are fed into the head through the center of the valve cover. Chrysler made a number of sizes of the Red Ram ram Hemi..I believe the first year for the Hemi was either 1951 or 52. Some engine sizes where 331, 354...the smallest one, again if I'm correct was the 1953 installed in the Cornet...it was 241 CID.
In 1956, Chrysler/Dodge came out with a Red Ram engine that wasn't a Hemi, it was 315 CID motor...the 2 4 barrel version made 295 HP and less optioned engines of this size made 230 HP. The Hemi for 1956 was 354 CID and with all engine options made 355 HP. In 56 they also came out with a 303 CID engine that produced 240 HP. I'm sure I missed something here, but it's a start.
Again...LOL...if I'm correct, the 392 Hemi didn't hit the streets until 1957.
So if you can check your valve covers to see if the spark plug wire goes through the middle or not, we can narrow things down.
Why change the push rods? Lifters may be all you need...further checking will tell.
Hope this helps
Ray
Old 09-19-2013, 05:14 PM
Matt, my apologies, welcome to the site...I'm not an engine guy, I'm more paint and body, so if my last post doesn't give you all the information possible, that's because I'm going by memory and after all these years on this earth, my human hard drive may be getting a little full...LOL.
I'm sure that with all the knowledge on this site you will be able to narrow down your quest to what size the engine is...I'm sure someone will come on with directions to look for certain numbers and that will tell you for sure of what you have.
Best of luck and enjoy the site.
Ray
Old 09-19-2013, 08:06 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks In Advance
Matt
I believe you will find the '56 Super Red Ram is a "Poly" head, not a Hemi head engine. 315 ci, IIRC.
Replacing the lifters w/o also replacing the camshaft is an iffy proposition. The lifter and cam lobe wear together into a non-separable unit; replacing the lifter on a used camshaft will cause accelerated wear in most cases. The accelerated wear can cause the lobe and lifter to wear so much that the lifter fails and the lobe cannot cause the valve to lift enough to allow the engine to run correctly. So consider either replacing the cam and lifters as a set, or to do further research into why the valve train is noisy in the first place.
More on breaking in a cam and lifters is here.
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
gonefishin' (11-08-2013)
Old 09-19-2013, 09:43 PM
I looked at the engine just a short time ago and it IS NOT A HEMI. As someone said, the spark plugs should be in the center of the covers.
Tomorrow, we will try and find numbers on the heads to see if the engine size can be determined.
Thanks
Matt
Old 09-19-2013, 10:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If it's the original engine, the displacement is 315 ci. D63-2-3 is what I see for the engine number.
53 dodge coronet 214 red ram baby hemi Purebluedoor Introduce Yourself 1 06-21-2012 10:12 AM
3x2 Red Ram Hemi Intake Stromberg 97s Engine 1 04-25-2008 07:54 PM
Super Red Ram: Poly or Hemi? jsrail Engine 14 05-25-2007 08:00 AM
super red hot headers burned me!!!!!! Scrumgees Engine 10 09-12-2006 09:17 PM
super ram intake steve1ph Engine 1 06-02-2003 11:50 PM
