Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Super T-10 bearing retainer question
Old 05-13-2013, 09:05 PM
Silver Surfer's Avatar
Silver Surfer Silver Surfer is offline
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by AutoGear View Post
Loctite 518 for aluminum to aluminum; loctite 5900 for aluminum to aluminum and loctite 242 (blue) if you're going to be in and out of the unit often. Thats from my Loctite Rep.
In the shop we use Valco aluminum colored RTV with their 'tube grip' dispenser. I HIGHLY recommend the Tube Grip if you use a lot of toothpaste type tubes of sealer. You can lay a bead so narrow you can write your name with it in script. Valco is out of Cincinnati and a great company to do business with.
I think I found the source of the leak...its a mysterious hole in the tail shaft. Any idea what this is for or what is supposed to go in there? From what I recall in the manuals there is no mention of this.
ID:	74001   Click image for larger version
