Super T-10 bearing retainer question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 05-15-2013, 08:28 AM
When Richmond went under; we lost a lot of our T10 business. Richmond was selling T10s through Summitt for less than I could buy one for with a 'wholesale account' Their prices got insane on parts and quality was going every which way. We had some stuff made in italy; I think I have some 2.64 1st gear ratio parts; and we can put rebuilder kits together; but a lot of your so-called 'hard parts' ie Midplates, castings and gearsets, I do not have. G Force is as good a place as you're going to find, they may hit you for a minimum order on a credit card transaction. Check your seals for the tailhousing, shifter shafts and pull the front bearing retainer (snout) and look at the little oil seal in there as well. You may want to replace them.
  #17 (permalink)
Old 05-15-2013, 10:53 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by lmsport View Post
1000043008 Midplate dowel
T10-55 OEM T10 gasket set
G-Force South
I am humbled, embarrassed, and elated! You are much better at the internet than I am! Fortunately for me I found the dowel mixed in with my bag of old parts from the rebuild. Crisis averted! Thank you all for helping!
  #18 (permalink)
Old 05-16-2013, 08:25 AM
Sweet!
Another 4speed back on the streets
  #19 (permalink)
Old 05-26-2013, 05:43 AM
hole in case
I made my own alignment pin from a drill bit. I forget the size. I measured the hole and matched up a drill bit and used the shank. Worked perfectly.
Ben
  #20 (permalink)
Old 06-06-2013, 10:15 PM
reed0380's Avatar
Dave Reed
Super T-10 mysterious hole
You are missing the alignment dowel pin which is supposed to be pressed into the mid plate. It pilots into a hole in the main case and also provides alignment for the tail housing extension. The original one may have fallen into the bottom of the main case. Let's hope it is stuck on the magnetic drain plug.
You can't insert the dowel pin from the outside of the tail housing because of the angled surface of the casting. You will have to remove the tail housing extension and that means the trans must be pulled from the car.
While you are at it, take off the side cover and retrieve the dowel pin from the bottom of the case. I do have several of them if you don't find it.
PM me (private message).
Super T-10 question MadMacs Transmission - Rearend 15 12-06-2010 01:20 PM
valve spring retainer question ap72 Engine 3 11-23-2008 11:30 AM
super t 10 question nick62877 Transmission - Rearend 5 04-24-2005 08:30 PM
Super T-10 Transmission question JamesRS Transmission - Rearend 3 09-30-2004 09:34 AM
Flowmaster Super 40 question Gametech Engine 1 01-16-2004 08:11 PM
