super t10? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-17-2007, 08:56 PM
super t10?
I need some help I bought a trans. I need to know how to decode to see what i got 25n531538 1304-065-903 wa1753 on the revese linkage numbers it has 13-04-097-901 and the forward gears it has 13-04-066-901 can any one help it also has a date on it of 8/19/74 stamped on the passanger side. 26spline input 32 on the out put thanks.
Old 08-18-2007, 12:44 PM
They call me ogre
here is some stuff on borg and warner T-10 or super T-10
How do I identify a General Motors Borg-Warner T-10 vs. a Super T-10?
T-10- Design I (1A): Apr. 1957 June 1959:
Cast Iron Case w/23/64 Bore, 3rd gear 1.37
No thrust flange for 2nd gear, Mainshaft 3rd gear has bushed hole, Reverse idler halves lock with 4 lugs
T-10 Design II (1B): June 1959 Jan. 1961:
Cast Iron Case w/ 1.5 Bore
Mainshaft 3rd gear has a ground hole
Reverse Idler halves are splined (27)
T-10 Design III (1C): early 1961 1962:
Aluminum Case
Everything else is the same as above
Except 1st gear bushing on Mainshaft was eliminated
T-10 Design III (1D): early 1963 mid 63:
Aluminum Case w/smaller bore than before
Mainshaft 1st & 2nd gears are given wider driving surfaces
Main drive gear re-designed
Snap ring clip was changed to threaded nut
T-10 Design IV (1E): late 1963 - early 1974:
(1stDesign SUPER T-10)
Aluminum Cases from GM & Cast Iron-After-Market
Offered TWO new gear ratios: 2.64:1 & 2.43:1
Side-Loaded w/side-lever shift linkage
Counter-shaft was enlarged to 1.00 inch
Mainshaft resdesigned redesigned for larger 1st gear Journal
T-10 Design V (1D): mid 1974 - 1982
(2nd Design SUPER T-10)
Same as above with MORE variations of a minor significance
Main Shaft is 32-spline
Gear Ratios are 2.43, 2.64, 2.88 or 3.42
Old 08-19-2007, 12:11 AM
http://www.dandltransmission.com/borgratio.html
They also sell parts.
Old 08-26-2007, 09:32 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
good info page... thanks jimfulco
Should I buy this super T10? quigman Transmission - Rearend 1 05-21-2007 07:15 PM
super T10 tranny in my 68 Camaro Pat Vines Introduce Yourself 0 09-19-2004 01:23 AM
Is there a good overhaul manual for the B.W. Super T10?? GMBrutus Transmission - Rearend 1 02-24-2004 09:05 PM
Super T10 Kits redcamaro4spd Transmission - Rearend 2 10-22-2003 11:09 PM
Super T10 or T10? Camaro2Fast4u Transmission - Rearend 4 01-13-2003 04:46 PM
