super t10 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2011, 04:28 PM
87fubar's Avatar
super t10
ive ben haveing problem with it going into revers an most the time when i can get it into revers it sticks is somthin worn or is it out of adjustment
Old 03-06-2011, 05:36 PM
WDCreech's Avatar
Grumpy Old Goat Herder
It sounds to me like your shifter is out of adjustment. Put the car on jack-stands and with the transmission in neutral, there should be a place on the shifter housing to align the linkage using an alignment pin.
Bill
Old 03-06-2011, 05:49 PM
87fubar's Avatar
what should i use for the alignment pin i seen were it go's when i pulled the shifter to clean it.thot that was the problem was realy dirty
Old 03-06-2011, 08:07 PM
WDCreech's Avatar
I used to use a small phillips screw driver, but anything that's about the right size will do.
Old 03-06-2011, 08:14 PM
87fubar's Avatar
wasnt shure if it had to be a serton size to align every thing right
Old 03-07-2011, 12:10 AM
junior stocker's Avatar
1/4" rod or 1/" drill bit usually fits. Be sure the shifter bushings are not worn. Hurst has replacements in both nylon and brass.
Old 03-07-2011, 12:42 AM
87fubar's Avatar
i already replaced all the bushings with the brass 1's. i changed them from the factory rubber 1's couldnt find replacements for the rubber 1's any were
Super rare Pontiac super duty found on auction... F&J Hotrodders' Lounge 40 11-17-2008 08:37 PM
Super C RV? 428ho Hotrodders' Lounge 3 10-02-2007 06:31 AM
super t10? CRAZY681980MV Transmission - Rearend 3 08-26-2007 10:32 AM
Should I buy this super T10? quigman Transmission - Rearend 1 05-21-2007 08:15 PM
Super T 10 71 c-10 Transmission - Rearend 2 03-16-2007 06:11 PM
