super t10 reverse pin - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-24-2011, 09:22 AM
joeyb's Avatar
ok guys i just got a b/w super t10 and it was sittin outside for a while so im taking it apart and i am going to rebuild it but anyway i am trying to get the pin that holds the reverse fork in and it just dosnt wana come out lol so do u guys have any tips on that and you think it would be possible to drill it out ?? also this is the first time i messin with a tranny so any other tips on doing this would be nice
thanks, joe
Old 01-24-2011, 09:55 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On the the shifter boss from If you look carefully at the end of the pin, you'll see that one end is larger than the other and can only be removed in one direction. Drive out the lock pin from the bottom of the boss to the top.
Trans is upside down:
Old 01-24-2011, 10:12 AM
big gear head's Avatar
High Performance Rear Ends
I've seen a lot of cracked cases from someone driving the pin out the wrong direction.
Old 01-24-2011, 10:21 AM
joeyb's Avatar
ya i saw that but it just stuck in there lol it dont want to move im trying to heat it up a little just maybe get it out but a steel pin in an aluminum case **** is prob frozen in there
Old 01-24-2011, 10:52 AM
I doubt that a drill will touch it. You will probably end up doing more damage to the case if you try to drill it out. The pin is hardened.
Old 01-24-2011, 11:31 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
thanks, joe
IF you use heat- be conservative! Aluminum weakens significantly when heated, and I certainly agree w/BGH about not trying to drill it out.
I would use PB Blaster on it, you could apply it after gently heating, even (do not breath the PBB fumes that will come off the hot metal).
I would start w/a sharp center punch in the exact center of the pin. That way, you're less likely to peen the end and make it larger. Give the pin a good, sharp rap, using a standard weight ball pein hammer- you do not need to take a drilling hammer/sledge to it.
It would be excellent insurance to use a simple block of wood to support the boss from below, so you're not hammering on an unsupported aluminum casting. It will only take a few minutes and could save you some big money, not to mention time and aggravation.
Use eye protection as a standard M.O.
Old 01-26-2011, 09:38 AM
Patience and a rust remover are what you need. PB blaster or ye olde coca cola; a few taps and keep at it, you'll get it. Note: no BFH and extreme care if you try to drive the pin the wrong way to shock it loose.
Super rare Pontiac super duty found on auction... F&J Hotrodders' Lounge 40 11-17-2008 08:37 PM
Super C RV? 428ho Hotrodders' Lounge 3 10-02-2007 06:31 AM
Should I buy this super T10? quigman Transmission - Rearend 1 05-21-2007 08:15 PM
Ms 69 1/2 Super Bee 691/2 Super Bee Introduce Yourself 1 03-10-2006 04:50 AM
Super T10 or T10? Camaro2Fast4u Transmission - Rearend 4 01-13-2003 05:46 PM
