Super T10 or T10? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2003, 08:23 AM
Question Super T10 or T10?
I have a borg warner 4 speed that much is true, but i cant determine if its a super t10 or t10
The numbers on the side of the trans are 1304065903
and i am certain its a fine spline shaft
any help would be greatly appreciated
Old 01-13-2003, 03:46 PM
BOBCRMAN@aol.com's Avatar
Post
regular t-10's were built in the sixties, they had the standard chevy three speed type input shaft and tailshaft. the first super t-10's built in the early seventies are also this way (about the first 500) then all were changed to the fine input spline and turbo 400 type output yoke.
Old 01-13-2003, 04:05 PM
Post
Go to 4speeds.com or gearzone.com they have tons of great pics and info. Zach
Old 01-13-2003, 04:19 PM
4doorjoe's Avatar
Post
check this site out they have some intreting info on t10 www.canadianclassics.com under t10 igot some usefull info there there should a stamped number on 9 bolt side cover which ids the year they say 1975 and up are as strong or better then M22 good luck it seem like any of the borg warner sites are tight with there info
Joe sammut
Old 01-13-2003, 04:46 PM
4doorjoe's Avatar
Post
4door i emailyou that page hope you get it ok
Joe sammut
