superbell i beam drop axel shock turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2012, 10:30 AM
have a 1934 ford with a superbell i beam drop axel . seems the shock is turning and hitting the axel when i hit a bump in the road . is lower shock mount defective , nut seems to be tight , nut is actually ressesed up into the lower shock mount . is there a special socket , regular socket doesn't fit . has this happened to anybody ? any help much appreciated !
Old 02-19-2012, 12:27 PM
shock turning
Have you check the shock bushings ?
Old 02-19-2012, 01:22 PM
RWENUTS's Avatar
Are your perch bolts and shock mount slotted for a keyway. Like these.
http://www.speedwaymotors.com/Lower-...DisplayId=3330
broken i beam axel rudds Hotrodders' Lounge 12 08-30-2012 08:53 AM
ford drop axel oldguy829 Suspension - Brakes - Steering 10 12-27-2008 08:15 PM
drop axel setup help PureC4 Suspension - Brakes - Steering 3 05-22-2008 07:36 PM
drop straght axel HELP 69bronco Suspension - Brakes - Steering 1 11-24-2006 09:04 PM
need model A 4" drop axel swseabee Suspension - Brakes - Steering 2 01-29-2006 08:56 PM
