Desk top Dyno requested
Ok guys thank you for the input. I have been crunching numbers ($) and I think I have a engine to build. I have decided to go with a non-roller hyd cam, see what you think. Would be great if someone could run this on desktop dyno for me, I think I have all the info. Exhaust consists of 1 3/4" primary 3/4th length headers to 2.500" duals through 2 chamber flowmasters.
Firestone, I meant a main stud girdle, but do you either is really necessary, I am pretty conservative (i.e. afraid of breaking things) behind the wheel so I really hope the stock rods/crank are ok. I scored a great deal on a fresh short block, all I planned to do is float the piston pins and turn a set of wrist pin buttons & put all my $ into heads & valve train (& ARPhardware). I have access to machine shop to build my own main girdle, that is the only reason I asked about it.
Here it goes.
B&M 144 Supercharger, 8psi boost max
Comp ratio: 9.0:1
Bore: 4.030
Stroke: 3.500
Rod: 5.956
Piston: SRP-138722
Head: AFR # 1387
2.02/1.60
Intake: 185cc
Exhaust: 69cc
Flow (int/ex)
.200 129/118
.300 189/153
.400 234/178
.500 267/185
.550 279/190
.600 282/191
Cam Specs:
Comp Cam Hyd flat tappet - custom grind
Dur @ 0.050 = 230/236
Lift = 520/523
114? lobe separation
I had planned to run a 2500 stall converter, currently using stock converter.
Reason: added info
