Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Supercharged Fuel problems
Old 06-20-2006, 07:57 PM
camaroman7d's Avatar
camaroman7d camaroman7d is offline
The guys are telling you correctly. Your carbs can't take 19psi of fuel pressure, that's why you were getting the black smoke and poor running engine. You may want to set your fuel pressure a little higher than 6.5 psi, do a little experimenting and see what works best. No boost reference needed.
