Okay ran the car with 8 1/2 psi fuel pressue, no boost reference. Off the line the car never hit the wheelie bars, 1000ft mark it broke up. Checked the plugs lean. Added jet, still lean, added more jet, still lean. 92 primary 96 secondarys still lean. Now for the trick question, we have a base timing of 32degrees and have a boost retard for the timing that is set at 1 1/2 Does anyone run a MSD boost retard? Should we just throw it in the garbage and set the timing at 29degrees
thanks
