***Edit: I answered your questions above, inside the quote.
Blowers
Yes the roots style is the classic way to go & a blower camgrind is needed, try 'Blower Drive Service' they have full bolt-on kits with the classic GMC style. The 100-150 hp increase is extremely conservative , Forged pistons are a must for the big HP numbers. And yes, intake port flow really doesn't mean much for street engines & exaust flow isn't really relevent either.
With the low CR forged pistons, cam, matching carb & a good ignition 700BHP is very doable...assuming you won't overtax the bottom end. ____________________________________________Rick.. ............ |
There is a lot of good info on the blower drive services website as well as other blower sites. If you stick with the stock setup on a 142 it will be fairly safe on a decent engine. The Weiand site also has a ton of good info. |
Yea, I think im going to stick with the weiand 142 for my vortec heads.
Cant seem to find any forged pistons that will give me the desired 8:1 or so CR with my 64cc heads though, lowest I can find is 9:1. And forged pistons are expensive! |
I've always dealt with powerhouse with pistons because they have a machine shop in their shop.I've been there,and had them cut the pistons to get me to my desired cr,according to specs I gave them.Very good work.
www.enginekits.com they might already have the right pistons |
Thanks, best I can find there is from probe pistons, 8.75:1 or so.
Are forged pistons needed for a supercharger because of excess psi or from the power? If im making 5-7 psi and 500 or so HP, are forged pistons absolutely necessary? |
you really should,but there not untirely necessary on a mild build.
I know people crazier than me that have got by with cast one but i'd never go less than hyperutectic
Yea, Ive seen quite a few articles using stock rot assemblies with blowers making in the 500hp range, think im going to stick with hypers at first, canalways upgrade to forged.
I havent taken a engine apart yet, but I can change the pistons without pulling the engine from my car right? Empty the oil Pull thepan Take off main caps Crank and rot assembly will come out then correct? |
I would think the cross member would get in the way,Plus most of the time the oil pan wont come off without lifting the engine,because the oil pump mostly.if I had to run hypers Id try to keep the engine as cool as possible.
I'll probably be running a clutch fan at first, but once the engine is in and tuned one of the first things I will be doing is definantly putting big ol electric fans in.
Other then that, how do I keep the engine cool? Keep a low temp thermostat in? |
Yeah a 165 thermostat
aluminum radiator(dont forget a tranny cooler) better oil(thicker) high flow water pump preferably high flow oil pump deeper pan |
Yes, You "NEED" forged pistons for anything over 4lbs of boost. Hyper pistons are cast pistons and have no place in a blown engine. It's your money you can pay now or pay more later, either way you will have to pay. Forged pistons are much stronger and can tolerate the higher heat that will be in the combustion chamber due to the added boost/power. With a cast piston if for some reason you ping/detonate the engine one time you will have a shattered piston, What do you think that rod and wrist pin will do to your bore/block? I'm all for getting the most for your money and taking calculated chances but, trying to run cast pistons in a blown engine is not a good idea.
How much power are you trying to make? Why do you want a blower? (for the look or to make power?). If it's for looks then just drop the boost down to 4psi or less and have at it. If you want to make power you need to get the parts to support it. The best suggestion I have seen so far is to buy the book called Street Supercharging by SA Designs. Before you spend a dime on an engine part you need to buy this book and read up a bit. I always suggest this book to first time blower guys. I have a very old copy of the book that I read for years before I ever started playing with blowers. Once you read that book you will have the basic idea of what's going on and how things work. It does not have all the answers but, will give you the knowledge to ask questions and understand the answers. I am in no way trying to discourage you, you'll love having a blown engine. You just need to build it right for the application. There's more to it than bolting on the blower, I know catalogs, web sites, ads, try to make it sound like ou just bolt on 250HP but, it doesn't work that way. Royce |
| Turbo vs Supercharger - Write up!! | FastChevyTruck | Engine | 107 | 02-16-2011 12:18 PM |
| Supercharger Help | scott011422 | Engine | 9 | 02-02-2007 04:18 PM |
| Age old question. Turbo Vs. Supercharger | Andyrew | Engine | 78 | 08-19-2005 07:35 AM |
| Possible/worth it? 3.8L supercharger on 305 chevy | Project87c10 | Engine | 9 | 12-20-2004 07:44 PM |
| supercharger problem | mad van | Engine | 1 | 06-23-2002 10:42 AM |
