-   -   Supercharger? (http://www.hotrodders.com/forum/supercharger-107165.html)
Artemis Entreri 01-20-2007 08:22 PM
Supercharger?
Ok, so i'm going to be building a 355 sbc soon.
Specifically I was looking at combo 78 here:
http://www.ryanscarpage.50megs.com/combos11.html
Now, this is already a lower compression 355.
Now mind you I have not done a lot of research on superchargers yet, but once this engine is built and in my car and I have money for it, I would LOVE to put a roots style supercharger on it.
Now I dont want to run alot of boost, maybe anywhere between 6-8psi or so.
My main questions are thus:
Which roots version supercharger would be good for a non-daily driven car that might see the track a few times?
Also, how is that cam for a supercharger? I believe you are supposed to downgrade the cam when you use one, but its not that big too begin with, maybe keep the 1.5 rockers?
And would I need a larger carb to make up forall the extra air i will be getting? If so, how big?
Are there any web pages that I can find alot of supercharger info? Ive found a few with snippets here and there, but id love to see a dedicated Supercharger page or something with lots of info.
Or, can someone suggest a book?
Thanks alot everyone
Steve
XNTRCI-T 01-21-2007 08:02 AM
Street Supercharging
pmeisel 01-21-2007 11:54 AM
Steve
http://www.carcraft.com/featuredvehi...d_350ci_chevy/
This article sounds similar to what you might want to do....
Artemis Entreri 01-21-2007 12:30 PM
Hey thanks for the book suggestion.
And that is a sweet article. Could build a little bit more of a performance bottom end, maybe a bigger cam and some more work done on my vortec heads and then just buy the supercharger and drop it one when I get the cash.
Thanks alot
68NovaSS 01-21-2007 02:21 PM
Pat Ganahl's book has a lot of good advice in it. I noticed the build #78 uses 8:75 compression, getting a bit high for a blower. The Car Craft article used an 8:25 motor, better, but I'd try to keep the compression even lower, maybe 8:1, that'll give you more room for increased boost if you ever got the urge....we all get the urge. Depending on what grade gas is available in your parts, consider a boost retard, nice to have that option.
Artemis Entreri 01-22-2007 12:16 AM
Thanks Nova, what is a boost retard? I mean, I assume it just backs off the boost, but how does it work?
Also, what is the difference to a carb used with a supercharger compared to a normal carbed dumped ontop of a engine?
DUKEOFBLUZ 01-22-2007 11:48 AM
Boost retard, is retarding your timing when you create boost.
I have a MSD boost retard box hooked to my MSD 6AL, you can set it as to how much you want it to retard your timing per pound of boost. Like lets say you have it set at 2 degrees, then for every pound of boost you make, it retards your timing 2 drgrees.
Duke
Artemis Entreri 01-22-2007 12:29 PM
Thanks alot Duke, i'll have to look into that once I get the engine together.
Pmeisel, do you know where I can find prices for that magna charger 122? Ive been searching around, cant find it anywhere.
If not, can anyone suggest a smaller supercharger for a 350?
Also, anyone know the difference between supercharger carbs, and normal carbs?
firestone 01-22-2007 02:41 PM
I think that car craft article would be a good place to start. As far as carbs go, it depends on if you have a blowthrough or if the air is drawn through. On the holley site, they have a carbeurator selector to help you find a carb that would work well. It kinda describes the differences.
You can go through it here, enter your displacement in the top right corner.
http://www.holley.com/
I went through it and came up with this one
http://www.holley.com/0-80572S.asp
Another option would be an intercooled procharger. It would probably be more expensive, but I think you could make about a 600 all else being equal to that in the article. With a procharger, you can run more boost because they produce less heat. On top of that, the intercooler reduces the heat of the air a lot also. At 8:1, you could probably run around 10 psi pretty easily. According to the procharger catalog, with an intercooled procharger, that can increase your your power by a factor of 1.7. 350 hp * 1.7 is 595 hp. If you look at the end of the procharger catalog, it tells you what kind of boost you can run with a given compression on pump gas. It assumes aluminum heads, but I just added a point of compression to simulate iron heads. I dont know if it works that way or not though.
here is a link to the procharger catalog I would read it, there is a lot of good info here.
http://www.procharger.com/pdf/Chevy.Prod.bb.pdf
Adam
Artemis Entreri 01-23-2007 09:11 AM
Thanks alot fire, as far as the procharger, I know that would be more efficient, but the roots style is just as much for the look and cause I like them then for the power it will give me. Plus hopefully it will cost less and be less work, Heh.
firestone 01-23-2007 02:03 PM
I understand, you are right about the cost and simplicity. It will still make great hp.
Adam
Artemis Entreri 01-23-2007 02:15 PM
Cant seem to find anything on the magna charger 122 they used in the article. Been thinking about going with another small SC, the weiand 142 or 144.
Anyone use one of these, yay or nay?
jameskirk1 01-23-2007 02:49 PM
I've got a real mild 355 with a Weiand 142 in my s-10...Here are some old pics but you get the idea...Runs mid 12's in FULL street trim...Keep in mind that this is with factory iron heads and a very small cam...
http://groups.msn.com/GearheadsPoorb...nw?albumlist=2
Some "hidden" costs involved that not many people mention...Plan on purchasing a blower calibrated carburetor unless you are a bonafide carb guru/megatuner...You will more than likely need to upgrade your fuel system to keep it fed at higher RPM...You will realize a GREAT improvement in performance with the blower by installing the largest headers/exhaust you can fit in the chassis with straight thru mufflers...The BTM is nice to have but make SURE you use some form of rev limiter - you WILL need it...You may need to upgrade your tranny for the torque levels you will be putting out and if an automatic will need a converter with a balloon plate...
Artemis Entreri 01-23-2007 05:11 PM
Thanks alot, thats a nice s10, how much does that truck weigh?
Are blower carbs that much more expensive?
Upgrade my fuel system, like a pump upgrade and stuff?
As for exaust I was going with headers right into glasspacks for now, wont be driving the car everyday.
BTM? Dont want to sound ignorant, but huh?
Like what kind of rev limiter?
Also, was your cam a off the shelf supercharger cam, or a custom grind?
And are those the stock pulleys that come with the 142 you are using with 8.5:1 cr?
Sorry for all the questions, but thanks.
Steve
HemmiGremmie 01-23-2007 05:42 PM
Hello.
You should definatly get the supercharging book and read up before adding one.
But if yer lookin 4 good power without spending a ton, you can get by with a lot more using a smaller roots type (like the Weiand 144 unit).
It will add great looks with around 100-125 horses by just bolting it on.
No need 4 fancy carbs. Get a nice Edelbrock 600-750 or a holley. On the smaller units (1440 you dont need a lot of xtra things.
Even small ports will work but you loose some power over like afr's, but cost is way less.
Im buildin a big 6-71 so let me know if you need help. Cya, HG
Chk out my project journal
