supercharger.... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-15-2010, 09:53 PM
that type in pic is a draw thru turbo setup .not very good the fuel and air go thru the turbo instead of just air as in a blow thru. if you run one turbo has got to have the carbon seal in it or your in trouble
  #17 (permalink)
Old 07-24-2010, 10:27 AM
carb cfm formula
So if I understand "techinspector1" correctly if I am running. A 350 @6000 rpm with 5 pnds boost, I'm running a B&M142, I should be running in the neighborhood of 800 cfm?
