supercharger - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2005, 09:42 PM
erythnul's Avatar
supercharger
ok i have a stock 93' 302 mustang gt engine and i've been thinking about buying a supercharger what are some things i need to upgrade on my engine right now to handle the increased hp? its probably gonna be a 6psi
Old 06-16-2005, 12:33 AM
Malibu73's Avatar
'68 Chevelle Malibu Sedan
Probably just make the bottom end stronger. i.e. forged pistons, forged crank etc...
Old 06-16-2005, 08:43 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
I have known a lot of guys just bolt one on and have at it, without problems, depends on what you will be doing with the car. Will it be a street driver or a track car? If you drive it on the street you should be OK with a GOOD stock lower end. 6psi is not that much boost.
Steve
Old 06-16-2005, 09:20 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Ditto!
You probably in all respect have to much compression right now to even run 6lbs of boost.
Unless you get lucky and only have 9-1 comp or so.
If you only have 9-1 comp then you can run about 6lbs, but just dont overev it until you find out if your pistons are cast or forged. It will look way cool though. HG
Old 06-16-2005, 12:30 PM
erythnul's Avatar
thanks
yeah my uncle said the engine has forged pistons and a steel crank
Old 06-16-2005, 12:55 PM
Try and figure your comp ratio and if its underr 9-1, then you should be ok with the 6 lbs of boost.
HG
Old 06-16-2005, 01:35 PM
segge's Avatar
The 93 engines didnt come with forged pistons
Old 06-16-2005, 02:04 PM
brainsboy's Avatar
brains
I bet you also dont have a steel crank.
Old 06-16-2005, 02:05 PM
Matts99Sierra's Avatar
yeah... if the CR is 9.0:1 or less you'll be ok without changing anything. but you will have to run 93 octane or better. because with a static CR of 9.0:1, with 6lbs. of boost added raises the effective CR to 12.7:1. which is pushing it a little because you'r not supposed to go past 12.0:1 without upgrading some parts. so you either want to drop your CR or underdrive your charger to run less than 6. if you dont you'll get detonation and litterally burn a hole through your pistons or melt your rings.
Turbo vs Supercharger - Write up!! FastChevyTruck Engine 107 02-16-2011 12:18 PM
Age old question. Turbo Vs. Supercharger Andyrew Engine 78 08-19-2005 07:35 AM
Possible/worth it? 3.8L supercharger on 305 chevy Project87c10 Engine 9 12-20-2004 07:44 PM
Supercharger fact or myth??? classic_chevy_guy Engine 31 04-03-2004 08:55 AM
supercharger problem mad van Engine 1 06-23-2002 10:42 AM
