supercharger and fuel delivery help wanted - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-24-2013, 04:38 PM
Hi all im new to v8 tuning i have a 67 impala with a 502 in it looking to supercharge but want to keep stock body appearance so want one i can mount in the same way you would an alternator are they available if so can you recommend some complete kit ideal as i need to import into the uk also fuel delivery considering changing to injection what are your views and recommendation should i just install better carbs. Any other advise appreciated as i said this is my first v8 and im setting it up fot the 1/4 mile.
many thanks
wozaa
Old 07-24-2013, 06:12 PM
Banned
really a 502 is no good? sorry ask one Q at a time. UK regulations will not allow a supercharger!
Old 07-25-2013, 03:04 AM
yes it will pretty much the only laws we have in regards to mods is how dark are front window tint is or what colour lights were aloud to use.
Old 07-25-2013, 04:40 AM
and i put both bits in the same post as i didnt know if there was a low profile charge out there that would fit under standard hood if i moved to injection.
Old 07-25-2013, 09:36 AM
ProStreetRob's Avatar
5.7L S10 LS SS
This is a Procharger F1R on a 502 with a Carburator
But you have to look at everything before pulling the trigger
How much compression do you have
How much Boost can you run
What centrifugal supercharger do you want
What Model head unit do you want
Are you going to run an Intercooler
What mounting and belt set up do you need
And of course do you have enough fuel system
I have a very powerful fully built 502 Solid Roller Motor with a big cam a 871 and (2) Modified Holley 750 HP Carb's. My fuel system set up is...
15 Gallon Foam Filled Aluminum Fuel Cell
Mallory 4150 High Pressure 140 GPH Electric Fuel Pump
Mallory 3140 Comp 140 Series Canister Fuel Filter
Aeromotive Fuel Pressure Regulator
Stainless Steel Braided Fuel Lines 8an & 6an
Aeromotive Digital FMU, Fuel Management Unit
Here's the link to Prochargers Chevy Catalog
Weiand also has a Small Compact 177 Twin Screw Supercharger for the Big Block Chevys they will fit under most Cowl Hoods
Example Here
Old 07-25-2013, 11:01 AM
ye that just the type of thing i want centrifugal. now i have the term that helps massively how do they compare to screw type powerwise. Ye i get i cant just add a charger i need to back it up with everything else just use to turbos. As for intercooler as no exhaust gas but ye all compressed air heats up how important is it on a supercharger
Old 07-25-2013, 11:30 AM
5.7L S10 LS SS
I dont have one on my Big *** Motor
But on a Centrifugal set up it is VERY IMPORTANT because you can run more boost and get MUCH BETTER results with an Air to Air Intercooler.
To answer your power question you can add up to 75% no problem with a Centrifugal SC. I added a full 60% on my old 99 Mustang GT with a little Procharger P1SC (which is the smallest head they make).
The pic I posted above is of a Camaro on the pro Charger site and the improvements were much better because they used a FR Head Unit
1970 502 Big Block Camaro
Description------ HP Gain----Intercooler
15 psi w/ F-1R -- 93% ----- 3 Core Race
Read up on their site, there's A LOT of info and examples of HP improvement
This is a little chart showing how important an intercooler is
If I fit an intercooler in a tight *** 99 Mustang GT believe me you can fit one in a 67 Impala no prob
Old 07-25-2013, 12:06 PM
right decided procharger f-1a intercooled where can i buy online that will ship to uk all the ones i can find are phone orders staying with carbs i think what do you recomend
carb, fuel delivery, help wanted, injection, supercharger
supercharge and fuel delivery help wanted wozaa3 Modern Electronic Engines 0 07-24-2013 04:13 PM
Low-buck SBC with supercharger - suggestions wanted hduff Engine 12 08-04-2009 08:09 AM
Fuel Pressure and delivery REM37411 Engine 2 07-01-2009 05:36 PM
info wanted: 1933-35 dodge "humpback" panel delivery trucks moparx Hotrodders' Lounge 8 12-07-2008 01:06 PM
fuel delivery problem meev182 Engine 1 03-20-2008 07:25 PM
