supercharger in my f100 - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2011, 02:01 AM
hi can any one help me ive got a 302 w supercharged its a 671 ive got 31 on bottom and 41 on the top it works out around 25% underdriven 5pound of boost what sort of boost can i get out on pump gas my comp is 8.44 -1 all the stuff in the eng is good stuff aftermarket block eagle crank je pistons Carrillo rods im just trying to find the best combo boost on pump gas we have 95 in nz
http://www.youtube.com/watch?v=UXNtG...7&feature=plcp
thanks steve (aka mrscko
Old 12-24-2011, 09:59 PM
I don't think I would go over 8lbs with 95 octane I would invest in a water /alky injection if I were running on the street. theres a couple guys on here that run blown on the street maybe they will chime in. My experience is on the strip with alky. how much boost do you need for the street? what do you have timing set at? what head gaskets? watched the vid I have always liked that body style truck
Old 12-24-2011, 11:04 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
X2 what Bantam said, if you can't swing a water/meth injection system, at least go for a BTM to pull timing at max boost. Detonation eats the good parts too. Depending on your gearing, tire size, etc., you can still detonate at 8 #'s, especially at 8.44 static c.r., that's pushing the high side for a blower motor.
Semper Fi
73 F100 W/360 recondoman Transmission - Rearend 2 07-19-2010 12:00 AM
50-55 f100 cab 54f100military Hotrodders' Lounge 1 04-11-2010 10:02 AM
yay new f100 72fordlb Hotrodders' Lounge 4 04-19-2009 11:54 AM
54 f100 captain kirk Introduce Yourself 1 04-12-2009 04:49 PM
53 F100 flatheads53 Suspension - Brakes - Steering 1 12-05-2006 12:28 AM
