supercharger problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2002, 06:19 AM
Red face supercharger problem
Hi, I recently purchased a Weiand 177 supercharger kit to suit a small block chev. After doing 600 miles I removed the supercharger to change the oil and noticed that the rear seal on the drive side of the rotor had chopped out the rotor and damaged the other rotor. The speed shop I purchased it from is replacing the supercharger with new replacement unit. Before I found this fault the supercharger had been working fine. I was wondering if anyone else has experienced this problem in such a short period or any period of use as the supercharger I have bought is designed for street use. I am quite happy with the supercharger's performance to date and not knocking the unit or the company I am purchasing it from. Any help would be appreciated. Thanks
Old 06-23-2002, 10:42 AM
HemmiGremmie's Avatar
Last journal entry: 52 truck
Question
Sounds like the rotors were not clearanced properly. How many miles did the supercharger have on it? Maybe it was just in need of an overhaul. Hope it works out for ya. HG
I was built with the body of a God! To bad it was buddah.
Hemmies rat journal below.
