Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Supercharger Roll,detroit Roll,blower Surge???
  #23 (permalink)
Old 07-17-2008, 08:05 PM
fatblock fatblock is offline
8-71 blown 461 Rat
That is the correct way to boost referance your power valves.the pv,s need to respond to engine load not the constant vacuum they see atop a roots blower.it is not unusual to see vacuum under the carbs with boost in the manifold.The carbs are a passive device and respond only when yanked on.Bigger blowers can and will pull more air thru a carb then its fuel delivery was designed for.This may help you understand why supercharger carbs for the street require different ckts and metering vs a n/a setup.
