Superchargers on a budget ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-18-2007, 09:19 PM
Hey everyone,
I was just thinking how great it would be to have a Blower on my 383 stroker ( all forged internals so it should hold the HP ) The real question is can it be done on a budget? I was thinking on the lines of a used M90 or twin M90s. I found some interesting articles,
http://www.autospeed.com/cms/A_2147/article.html
http://www.autospeed.com/cms/A_2149/article.html
I just need some steering in the right direction, something that has a SBC intake manifold. Would I be better off just getting a 177 ? I'm not looking for a lot of boost, I have 9.3 compression but figured I would run a water injection system to control detonation.
Thanks
Jordon
Old 05-18-2007, 09:28 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What is your budget like? A 177 would definitely make your engine come alive. I stuck a 142 on a 9.7:1 350 and the difference was amazing. It makes about 6psi of boost and it'll run fine on straight 92 octane as long as I don't get crazy with the throttle. Of course, there's no point in having a supercharger if you don't make use of it so I usually run about an 80/20 mix of 92 and 114 octane. It's been on there for about a year and a half now and so far the cast crank, two bolt mains and hypereutectic pistons are holding together.
I say if you can manage the cost of the 177 then go for it. It's a kick in the pants.
ahhh what do I do? mixed up beraing cups, budget 8.5" posi install Warrant Transmission - Rearend 7 03-23-2007 09:39 PM
Budget hotrodding dead? 78 monte Hotrodders' Lounge 19 09-26-2006 07:25 PM
PSI Superchargers Flywhel Engine 19 02-21-2006 09:46 AM
Something different: dual centrifugal superchargers StevenC Engine 14 08-23-2005 11:10 AM
Budget muffler recommendation fearsomefairmont General Rodding Tech 3 06-26-2005 12:11 PM
