Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Superchargers on a budget ?
Old 05-18-2007, 08:28 PM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
What is your budget like? A 177 would definitely make your engine come alive. I stuck a 142 on a 9.7:1 350 and the difference was amazing. It makes about 6psi of boost and it'll run fine on straight 92 octane as long as I don't get crazy with the throttle. Of course, there's no point in having a supercharger if you don't make use of it so I usually run about an 80/20 mix of 92 and 114 octane. It's been on there for about a year and a half now and so far the cast crank, two bolt mains and hypereutectic pistons are holding together.
I say if you can manage the cost of the 177 then go for it. It's a kick in the pants.
