supercharging help - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-06-2006, 11:28 AM
supercharging help
where do i need to start? i have a 383 stroker and i want to supercharge it what do i need to do to make this happen? what copression ratio and piston type do i need to use?
Old 08-06-2006, 12:14 PM
Wiki Edits: 31
it all depends, generally you can run up to 8psi on stock stuff. 8.1-8.5:1 compression recomended. a Wieand 144 or 142 Blower is great for this. set stock for 5-7 PSI boost, will work great and give you about 40-60% more HP.
Supercharging up to 2hp per CI brainsboy Engine 8 02-01-2006 08:03 PM
turbo or supercharging Pontiac engines Schoust Engine 12 01-26-2004 03:43 PM
Find my options for supercharging? unseenthings Engine 1 09-16-2003 03:05 PM
Forged crank, pistons, and supercharging CustomFord Engine 3 09-01-2003 01:48 PM
Supercharging a Carbuerated 350 Chevy Brandon Potter Engine 1 01-24-2002 07:35 PM
