Superlight Scat Crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-18-2012, 09:03 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
I haven't bought a crank for my 496 stroker yet. Gen VI block.
Scat has a forged regular weight 4.25" crank for the one piece seal at 70LBS.
I could get the super light forged crank at 59 LBS. This one would require a seperate seal adaptor as they're only available in the two piece style.
If the extra cost is not a factor and this is going in a high compression, high torque street motor, looking for good cruise characteristics and engine smoothness, will the 11 LBS weight savings help?
Old 03-18-2012, 09:12 AM
techinspector1's Avatar
Wiki Edits: 326
If I were building the motor for a class of competition, then I would want every advantage I could buy and would not hesitate to use the lighter crank, no matter how much it cost.
If I were building a motor for good cruise characteristics and engine smoothness, I would build a low compression motor so that I could use a short cam with short duration, ground on a 112/114 LSA. If you build a high compression motor, then you will have to use a tall cam with lots of duration to prevent excessive cylinder pressure and I don't think you will be happy with the results.
Old 03-18-2012, 09:42 AM
BOBCRMAN@aol.com's Avatar
Not worth the cost and hard to balance, Mallory is costly, unless you are using an ultra light rotating assembly. Two piece adapters are also $$$.
I had a customer go this route and the Mallory metal cost $400.00 plus the cost of the balance $225.00
Old 03-18-2012, 10:32 AM
123pugsy's Avatar
"Thread Cop"
Wiki Edits: 29
Thanks guys.
The compression won't be too high at 10.4:1 with aluminum heads.
I should have stated cylinder pressures will be high with 8.4 dynamic.
It will be a short cammed (somewhere between 210-220 duration), fuel injected torque motor.
So if weight is not a huge factor for a smoother running motor, I can save about 600 bucks on the crank and seal adaptor.
I'm just thinking of how to put together the best cruising and most fuel efficient motor (including long highway drives) that I can. I know BBC's and fuel efficiency should not be in the same sentence but a couple miles a gallon these days is great savings at the pump.
Eagle or scat crank?? what would you use? tiresmoke55 Engine 24 08-31-2011 11:05 PM
Scat crank question hemigremmy Engine 5 03-17-2009 07:55 AM
Scat Cast 9000 crank....? PairOf69's Engine 9 09-14-2008 08:12 AM
Scat crank 1969NovaSS Engine 2 07-12-2006 05:56 AM
Scat 9000 crank VS stock 400 crank? MOORESPEED Engine 5 03-03-2005 10:54 AM
