Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Sure fire way to find TDC ?
Old 05-01-2002, 07:05 PM
54 Chevy's Avatar
54 Chevy 54 Chevy is offline
Question Sure fire way to find TDC ?
What is the best way to find TDC on a small block Chevy? The engine is assembled (not by me) and I think the distributor was installed wrong by a few degrees. I'm using a HEI distributor.
Ive heard something about pulling the rocker covers cranking the engine and watching for some particular valve set to be open or closed or something. How will I know when they are open or closed? Do I have to crank it enough to pump up the lifters?
Once I determine I'm at TDC shouldn't the timing tab line up with the timing mark on the harmonic balance?
Thanks <img src="confused.gif" border="0">
