Sure Grip or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-23-2011, 11:13 PM
mitmaks's Avatar
Last journal entry: Grille
Sure Grip or not?
So my Charger should have Sure Grip installed (68 R/T)
Once I jack up rear wheels they spin opposite of each other (open rear end right?) However I had to take it out of garage a few days ago and then was bringing it back in and end result are two patches of rubber left on my driveway what gives?
Old 07-24-2011, 07:34 AM
SSedan64's Avatar
Should be an Open Diff.
An Open Diff can leave dual patches in straight line accelleration.
Old 07-24-2011, 08:18 PM
diff
^x2 if traction is equal both wheels get power
Old 07-31-2011, 03:03 PM
cranky1's Avatar
Just stuck
The Sure Grip was an option on all cars no matter if it was an RT or not. If you jack up the rear and turn one tire and the other goes in the opposite direction, it's either worn out or you don't have one. If you have a build sheet, it'll tell you if it has one or not and the others are right....an open diff can lay down two tracks if conditions are right.
Auburn sure grip rebuild? DadTruck Transmission - Rearend 9 02-14-2010 12:12 PM
Vise Grip goes to china C-10 Garage - Tools 45 10-22-2009 11:32 AM
is it a sure grip or is it not? fordsucks7 Transmission - Rearend 0 04-13-2009 06:50 PM
Bolt-grip cletis Garage - Tools 6 01-16-2006 07:43 PM
Sure-grip vibration wvrodder Transmission - Rearend 10 09-26-2002 03:43 AM
