Surface rust - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2006, 02:02 PM
57halfton's Avatar
Surface rust
I have another big window cab for my 57 Chevy pickup. The guy I bought it from had it dip striped then it was primed , I don't know if it was sprayed or dipped to prime. Anyway when it was stripped the acid took the caulking out of the drip rail then it got wet out in the backyard when the tarp blew off in a rain storm so water got past the spot welds in the drip rail into the inside of the cab between the interior sheet metal and the outer sheet metal , now I have rust scale coming out from the pinch weld where the rear window rubber goes.
Any ideas on how to get to this surface rust between sheet metal panels where you can't see before it turns into a real problem?
Does any of this make any sense?
Thanks, Gene
Old 07-29-2006, 04:32 PM
scrot's Avatar
Try a chelating solution. You'll have to let it flow through the gap until it is gone. rust cleaner
Once it's gone, I don't know what you can use to stop it.
Old 07-29-2006, 05:00 PM
steve t's Avatar
ex biker, now hotrodder
buy some rustmort, at paint store, you can spray it in cracks with spray bottle
secrets of surface rust removal revealed Randy Ferguson Body - Exterior 178 09-24-2011 10:36 AM
Rust Dissolver versus Rust Convertor? 66GMC Body - Exterior 9 11-06-2005 06:48 PM
surface rust mercury88 Body - Exterior 1 08-03-2005 11:45 PM
surface rust removal michiganjoe Body - Exterior 3 06-07-2004 03:48 PM
Surface Rust Benji Body - Exterior 7 02-25-2003 07:36 AM
