Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Surface Rust/Rust Mort...teach me please.
Old 06-25-2012, 07:13 PM
John long John long is offline
Search the forum for threads on Ospho. They are similar products. You will need to get the remaining paint off the car and really work the rustmort or Ospho into the rust If you really work it, it will disolve and remove the rust. CLEAN WELL with wax and grease remover and prime with a good Epoxy primer that will give it protection from moisture.
Good luck
