Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Surface Rust/Rust Mort...teach me please.
Old 06-27-2012, 06:45 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
I see this all the time ,The REAL problem is the primer that was used .Lacquer primer (spraycan primer) will do this every time because it allows moisture to soak in down to the metal making it rust...All that primer has to come off and the car needs to be stripped down to the metal(.you can do this in sections)Take care of the rust then use epoxy primer over the metal.You really need a compressor first and a DA sander the good primers only come in a can and need mixing then sprayed on with a paint gun...np sense doing anything until you get the basic tools you need...compressor ,Da sander, paint gun..
