surface rust treatment - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2004, 10:14 PM
coolP11's Avatar
I have a 1941 Plymouth that I am working on.It is covered with light rust.The car has limited final value and I am building it on a budget so media blasting is out of the question as well as any chemical dip.Yet I want the finish to last.I had the hood sand blasted,I gave the operater instructions to hit it hard around the edges but just dust it on the large ,flat areas that are prone to warpage.The rest of the body will be done likewise.The dusting did clean off some of the rust but not all.Should I hit it with a rust preventer such as por 15 or rust bullet to seal whats left of the rust in or just go ahead and prime and paint?
Old 07-27-2004, 10:25 PM
Danny63's Avatar
Surface Rust
Try sanding the surface rust off with a palm sand er with medium grti,12-180 grit sandpaper
