surging idle - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2010, 11:25 AM
powered by 1.21 gigawatts
surging idle
got a 88 350 basically stock....i have a wieand 8004 manifold that i enlongated the center holes to fit the engine.....edelbrock 1406 carb seems to surge when running and it will idle up and down any ideas
Old 06-06-2010, 01:28 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Have you recently rebuilt the carb or done any other changes like distributer ?
If some of the passages in the carb are blocked it can do this. If and When you rebuilt the carb if you did or had it done, Were you careful to blow out all passages? And i even use a thin wire to make sure they are all clear. Or it's best to have the carb boiled if you can.JMO
You need to Check the float level and make sure the float isn't getting partially filled or that the needle valve and seat isn't working loose.
Check out the advance weights in the distributor to make sure they are working right also, and make sure the vacuum system does not have a leak somewhere.JMO and if you enlongated the center holes to fit the engine could be a leak there that's where i would check first. If this is all that you have changed then it's more then likely where the problem is.JMO
Cole
Carb tuning issues - 750 speed demon lightningcow Engine 57 07-01-2009 07:32 AM
Blower Motor - Timing - Spark Plugs: Need Clarification Please 41willys Engine 22 08-31-2008 10:01 AM
1967 pontiac 455 overheating brisk Engine 12 04-03-2008 10:17 PM
DARK brown--BLACK plugs SBC Joshua Lee Engine 130 02-03-2008 09:12 AM
Too much camshaft!? pi71 Engine 28 04-10-2007 01:18 PM
