suspenison travel room?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2008, 10:39 PM
Jr 1948
Last journal entry: frame painted and motor is in
how much room should there be inbetween the frame and rear end I've herd of 4 inches should be lots of room for travel upwards but just wanna make sure
Old 09-07-2008, 12:46 AM
powerrodsmike's Avatar
Wiki Edits: 161
It really depends on your car and spring rate etc...With 4" of travel on a fairly light car you should rarely bottom out. Use some 1 1/2" tapered rubber bumpstops, and you'll be ok.
I just set up a rear end on a guys model A with about 4" of travel and he is all happy. He had about 2" before, and it bottomed out hard all the time.
Later, mikey
BE different....ACT normal.
Old 09-07-2008, 02:30 AM
Jr 1948
yah I will go for 5 inches first and if no problem I'll lower it another inch but I'm running 4-link with coil over shocks
Old 09-07-2008, 02:57 PM
I always shoot for 3 inches between a solid rear axle and the rubber bumper with the vehicle LOADED. i.e. the normal compliment of friends in the back and tools in the trunk.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 05:15 AM
Running out of room :D Stovebolter Suspension - Brakes - Steering 6 05-14-2008 07:02 AM
Motel 6: Would you like your room to smell like smoke, or just cat pee? bullheimer Hotrodders' Lounge 8 01-02-2004 05:11 PM
