suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2004, 04:53 PM
New Member
suspension
I have a 67 GTO that recently had the from suspension completely rebuilt. When this was done the front end is now about 1 inch lower that it use to be. Is there an easy way to raise the front end 1 inch? everything else is great, no rubbing or anything like that, I just prefer the way it sat before. As always any and all help would be greatly appreciated.
Rick In Hanford Calif.
Old 06-10-2004, 10:56 PM
93_406cobra's Avatar
Did you put new coil springs in it.
Old 06-15-2004, 11:24 AM
New Member
I did not put in new coil springs.
Old 06-15-2004, 12:14 PM
poncho62's Avatar
Wiki Edits: 5
Probably should have. The new bushings etc that you put in let the suspension bind less, so it sits a little lower.
Old 06-17-2004, 09:57 AM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
A cheap fix are the knuckles that go inbetween the coils. It makes for a stiffer ride though depending on how many you need to get the hieght back. You can get em at your local Kragen or the like shops.
Old 06-17-2004, 11:33 AM
BOBCRMAN@aol.com's Avatar
Next step up from the screw in knukle type, is the 1" rubber coil spring spacers that fit between the spring and the spring seat.
Old 06-17-2004, 12:15 PM
New Member
BOBCRMAN
Regarding the 1" rubber coil spacer. I've never seen them, any idea where to look?
Thanks
Old 06-17-2004, 12:40 PM
They are available at the same types of places as the knuckles, but look like "discs" in a way. They cover a whole ring of the coil and fit in between them.
