Suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-15-2004, 09:37 PM
TWOPLYM's Avatar
New Member
Suspension
MY PLYMOUTH HAS "A" ARM SUSPENSION BUT THE SHOCK IS CONNECTED TO BOTH UPPER AND LOWER ARM(RIDES ROUGH) CAN I RELOCATE THE TOP SHOCK MOUNT TO THE FRAME OR SOMETHING LIKE THAT- BRACKETS,KITSSOMEONE PLEASE HELP
Old 12-16-2004, 07:49 AM
Wiki Edits: 49
A picture would be very helpful. I've never seen a setup with the shock mounted to both the upper and lower "A" arms and it doesn't make sense to me why someone would do it that way.
Also, using CAPS is considered YELLING. Please refrain from using caps unless you intend to yell.
Centerline
Moderator
Old 12-16-2004, 03:06 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
i think i know what you're talking about. get the latest issue of Rod & Custom, Jan. 2005.
they do a brake and shock upgrade on a '51 Plymouth. starts on page 49. It shows the original shock as you describe. They end up welding some brackets onto the frame and mounting the shock from the bracket down to the lower arm.
Actually, check out this link to the R&C website.
hope this helps.
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 12-16-2004, 05:06 PM
Wiki Edits: 49
Now that's an odd-ball setup if ever their was one.
Centerline
