Suspension/brake issues arising from putting a bigblock into Chevy Nova - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-28-2002, 04:37 PM
New Member
Post Suspension/brake issues arising from putting a bigblock into Chevy Nova
Are there going to be problems? I expect to have to beef up the springs in the front at least. Will the added 900lbs of engine and transmission require upgrading to more effective brakes?
Old 12-28-2002, 05:50 PM
Post
[quote]Originally posted by Tyrfin:
<strong>Are there going to be problems? I expect to have to beef up the springs in the front at least. Will the added 900lbs of engine and transmission require upgrading to more effective brakes?</strong><hr></blockquote>
It is always a good idea to upgrade suspension to handle the added power and weight.
Where did you get the 900 lbs figure? A 454 and a turbo 400 does not weigh 900 lbs.
The added weight over a small block would be in the neighborhood of 200-250 lbs. You will need to flip the heater core too for heater hose clearance. See photo here:http://www.pe.net/~jroberts/Nova_engine_2.jpg
Go here for the difference:http://www.pe.net/~jroberts/heater-core7.jpg
:p :p
