suspension/clearance problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-13-2010, 05:52 AM
I put on a conversion brake kit on my 1965 impala when i set the car down driver side tire was hit lower tip of fender. Went to get alignment had problems with that. Changed out front suspensionupper/lowwer ball joints
Old 11-16-2010, 07:17 AM
Wiki Edits: 27
binding bushings
you can but a bind in the system if the parts are torqued and not in the level ride height positions
Old 11-16-2010, 07:53 AM
Isn't this as simple as the new brakes moved the wheel out and that is all there is go it? I don't think this is rocket science, the new hub or spindle or what ever you put on moved the wheel mounting out further widening the track.
Either you go back to the brakes you had or you change the tires and/or wheels. I don't think there is much to think about here.
Old 11-16-2010, 06:44 PM
Thanks. I checked that after the posting. Your good.... Real good.
383 stroker problems and ways to fix them leftoverchrisac Engine 15 02-06-2009 05:36 PM
Olds 98 Ignition Module Problems awbazar Electrical 1 01-12-2004 06:42 AM
beater car problems 02 0n 20s Engine 2 11-01-2003 06:53 PM
Light Problems like crazy ponybuster Electrical 7 10-14-2003 12:12 PM
LT1 knocking problems gollygwagen Engine 0 04-23-2003 05:52 AM
