Suspension gurus
I just created a suspension article on the wiki trying to make it as diverse as possible. Getting this together can help answering alot of the common questions.
if you are bored help me out everyone feel free to nitpick what little I have and write up your own info this is the best thing about wiki's even you can add to it. http://crankshaftcoalition.com/wiki/Suspension Last edited by ChevyThunder; 09-13-2006 at 02:32 AM. |
Personally I call this a Triangulated 4-link in order to differentiate if from other types of suspensions. You can be even more descriptive by calling it a single triangulated 4-link as only the top links are triangulated in the case you spelled out (either the upper, lower, or both sets of links can be triangulated). The true downfall to this suspension is that it has compliance oversteer. That is the harder the car turns (pull more lateral g's) the more the axle will turn sharper because of the soft rubber bushings.... ...I will try to go into more as I have time. I need to get to bed |
Well thanks for the info. I would post it however you are much more knowledgable then me in this area feel free to edit my work because I am sure there is alot more you can correct me on and you can probably do a better job of explaining things. This is the wonder of a wiki.
My only comment: Why?
All of this is already available online. I admire your willingness to take on a truly monumental task, but there's really no purpose. The information is already available. And, what you've done would be easier to read if you had run it through a spell checker. |
Nice work on that article. It's coming along nicely.
Agreed -- all of the information is available elsewhere. Placing it in the wiki accomplishes 2 specific goals: 1. findability: the information is easily accessible, all on one page 2. knowledge-sharing: information entered into our wiki is published under a special license that allows anyone to copy it, place it on other webpages, print it out, pass it around, etc. This ensures that copyright "restrictions" won't prevent the sharing of this information.
HomemadeTools.net -- Thousands of Homemade Tools |
Okay, okay! You guys have succeeded in making me feel guilty. I've gone back and made some contributions and will add more as I have the opportunity.
I just added the Truck Arm's...what year did chevy start using them
Triaged,
In your previous post in this thread you promised: Quote:
The result will be a "Cruiser" with no plans to race, but would not like to be embarrassed by a "ricer" at every stop light. Before I knew any better, I completely rebuilt the suspension (including the rear control arms) using a Polygraphite bushing kit from PST. Should I change out some/all of the Poly rear control arm bushings to another material (the arms are stock)? Thoughts re "boxing" the control arms? Appreciate any help and/or suggestions. texastomeh |
BillyShope -- thanks for the contributions. I've added a "barnstar" image to your username. Barnstars are wiki symbols of "barnraising", the act of coming together to perform a task to help a community. They were found on early American barns. You can see more of them in this gallery.
Don't worry about any errors to an article. They are extremely easy to fix, so feel free to make as many as you like while you learn the wiki process . Also, every time that a wiki article gets edited, the previous version gets saved (so the larger articles will have hundreds, or thousands of previous versions saved). We can easily "rollback" to any previous version of an article, anytime. If you want, you can always practice editing on our: Practice Page.
When you use the equals signs as headings, like this: ==Leaf Spring==, it results in a separate section being designated. Each separate section gets its own edit link.
Okay, I'm beginning to get the hang of it. Corrected my mistake, anyway.
| Hotrodders Knowledge Base: Suspension - Brakes - Steering | Jon | Suspension - Brakes - Steering | 0 | 11-26-2005 06:29 PM |
| Mustang II suspension guru's | Seijuro | Suspension - Brakes - Steering | 6 | 11-11-2005 08:51 PM |
| Rack & Pinion Steering on a Chevy C-20 Suspension? | Dusty82 | Suspension - Brakes - Steering | 3 | 03-01-2005 09:15 AM |
| how to hang a C- 4 suspension ? | Redmist | Suspension - Brakes - Steering | 1 | 12-31-2004 11:48 AM |
| Mustang ii Suspension | 41fordcoupe | Suspension - Brakes - Steering | 14 | 06-11-2003 08:12 PM |
