Does the rear suspension have lowering blocks? The reason I ask is that it is not uncommon to have a ride height difference as you are describing. What works well is to modify the lowering blocks to adjust out the difference. Either shorten a tall one (preferred) or make a taller one for the low side.
It could be either the front or rear springs causing the problem. As to the sway bar, it can also pre-load a suspension. Just disconnect it on one side and go for a drive and re-measure to find out. Andy |
Great idea on the lowering blocks - never thought of that. I'll check the sway bar tomorrow. Thanks again. |
It could definitely be a weak spring. I've got a 69 Corvette I've owned since 71, and the left front spring on it was weak and sagging noticably by the mid-70's when the car only had maybe 70K miles on it.
Waaay back I had to replace the front coils on my '75 Nova because one had the end of a coil broken off. Always replace as a set. BTW there are different rate springs available. IE 6 cyl or V-8
| Passenger side dip vs driver side dip in early Nova | dirtinla | Engine | 1 | 11-20-2008 12:45 PM |
| Weird problem, rear moves side to side?? | Nova_63 | Hotrodding Basics | 5 | 09-07-2008 08:47 PM |
| roller rocker tips off center from side to side | awoodman | Engine | 8 | 11-17-2007 08:25 AM |
| How much side to side movement does a rear axle make | STATUTORY GRAPE | Suspension - Brakes - Steering | 9 | 11-23-2004 06:23 PM |
| one side is1.75" lower than the other side. | brian400ex | Suspension - Brakes - Steering | 15 | 04-01-2004 04:34 PM |
