Suspension help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2009, 05:09 PM
Bob88's Avatar
Suspension help
I want to put a straight axle on this 29 Chevy frame. Anyone got any pictures of a similar frame with a straight axle that I can look at. I'm having trouble deciding where the spring perch should be mounted. Any help would be appreciated.
Here's a pic of the frame. Thanks.
Old 07-09-2009, 03:24 AM
327NUT's Avatar
Howdy and welcome......just a shot in the dark here but are you going to mount the spring on top or behind the axle?? I would think that you would mount it to center the tires in the fender..........IF you're running fenders.
Old 07-09-2009, 12:55 PM
Bob88's Avatar
Not going to have fenders. If the perch is mounted on that cross member near the front of the frame, then it will be behind the axle, but the part of the frame forward of the cross member looks like it may interfere with the axle. Thoughts??
Air ride suspension geometry tubbedz Suspension - Brakes - Steering 6 04-13-2009 09:01 AM
Powder-coating the suspension - ?? hd_rider Suspension - Brakes - Steering 3 09-29-2008 04:55 PM
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
