Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - suspension help for 65 stang
Old 08-07-2002, 11:00 PM
68mustang 68mustang is offline
I had the same problem you are having as far as the car rolling around. Try checking the tie rods, center link, and the idler arm for excessive play. Check the shocks and the springs for wear. Also, check the bushings on the lower control arms. As far as the sway bar question, you'll notice a lot of improvements with a bigger sway bar. Just listen to deuce_454 about the rear sway bar. I used a 1 1/8 front sway bar and a 3/4 rear sway bar on my '68 mustang and it made a lot of difference. You'll definately want to get the car aligned after any suspension part change. Hope this helps.
