suspension id help needed!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-16-2011, 08:48 AM
hi i`m new here
i`m building a 53 chevy truck
i want to upgrade the suspension however some one has welded a font clip from another car on to it but i dont know witch make ore model
it could be a pontiac because the steringcollum came out of one
looks quite similar to the second gen camaro but the dimensions of the mountingbolts don`t match
they are 6.5" and the second gen camaro is 7.5
tryed to upload pictures but failed
PLEASE HELP!!!!
Old 01-16-2011, 08:56 AM
matts37chev's Avatar
& matts38chev
Last journal entry: Try again
Originally Posted by chrisgomes
hi i`m new here
PLEASE HELP!!!!
i would work out the pic thing, then maybe some one can help
oh by the way
welcome
Old 01-16-2011, 10:53 AM
photos of the front clip
youre right hope these help
here som pics of the front clip
ID:	51731   Click image for larger version
Old 01-16-2011, 12:48 PM
Wiki Edits: 49
That's a GM clip of some kind for sure. If the dimensions aren't correct for a Camaro, it could be a Nova.
Old 01-16-2011, 12:53 PM
that was what i was thinking however its not a 1 gen camaro because of the front steer and not a second gen because the upper mounting bolts are 6.5" and a second gen is 7.5"
hey your probably gonna love the engine thats going in
a 241 dodge red ram tuned by moritz racing here in holland
Old 01-16-2011, 01:31 PM
ericnova72's Avatar
More for Less Racer
Looks like '64-72 Chevelle/Lemans to me...front steer but the earlier narrow bolt pattern to the A-arm. Measuring the spring OD will help, '64-72 Chevelle/Lemans is 5" OD spring, '73-77 Chevelle is 5.5" OD
You're right, it isn't second gen Camaro(or first gen either).
Old 01-16-2011, 02:07 PM
wel i`ve measured the spring and its 12.5 cm witch is about 4.92 inch
but not really sure if that was wat yo ment with OD
Old 01-16-2011, 02:28 PM
Are the steering arms and caliper brackets integral to the spindles or do they bolt on? You may have to scrape the crust away to tell for sure. The 64-72 A-body spindles have bolt-ons, the later cars have integral.
Old 01-16-2011, 02:32 PM
they are bolted on i know because i`m starting to disasemble the suspension so i can make some acured measurements of the lower control arm for the guy at ridetechs
Old 01-16-2011, 03:20 PM
OK, you have a 64-72 GM A-body front suspension (Chevelle, Cutlass, GTO, etc). Note that the 64-67 frames are about 1.5" narrower than the 68-72 frames, so parts like the center link are different.
Old 01-17-2011, 09:53 AM
just got the lower a arm loose and its 38.1 cm long perpendicular from te mouting bolts to the ball joint does that sound about wright?
Old 01-17-2011, 10:18 AM
ericnova72's Avatar
More for Less Racer
I can't help you on the A-arm length measurement, but the front steer, 6.5" upper A-arm cross shaft bolt pattern, bolt-on steering arms and 5" outside diameter(OD) coil springs all point directly to '64-72 Chevelle/Lemans.
rear suspension change needed? grouch Suspension - Brakes - Steering 16 09-23-2006 08:02 PM
Rear Leaf Suspension 49 Chev 3/4 Ton, Suggestion Needed! lazydawg Suspension - Brakes - Steering 1 09-06-2005 06:32 PM
Where to buy Suspension Bushings for Custom Suspension? bigfred1958 Suspension - Brakes - Steering 6 08-23-2004 03:55 PM
any mechanics done suspension work on 88 thunderbird needed here! FoxThunder 5.0 Suspension - Brakes - Steering 12 08-03-2003 02:12 PM
