suspension issue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2010, 02:11 PM
suspension issue
72 chevelle,upper and lower control arms are not yet tight,springs are in rightside up and clocked right.yet i cannot jack the lower control arm up enough to meet the spindle and upper balljoint without the whole car lifting off the stands.the car is all together with engine and tranny in place.any help would be great.
Old 11-06-2010, 05:01 PM
Are you sure the upper end of the spring is properly located over the cylindrical seat in the frame? It's not possible to see the top end of the spring, and it can slip out of place and the cylinder will be sitting on top of the spring instead of inside it. You usually need to wiggle the top end of the spring by hand as you locate it in the frame, then hold it up against the upper spring seat while you pull the lower control arm up to hold it in place. Don't be surprised if the spring drops out of place the first time you try this.
Old 11-06-2010, 05:10 PM
yes the spring is seated fine in the frame,thats why i don't understand it.i've taken it apart 3 times,soooooo frustrating
Old 11-07-2010, 11:45 AM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
Try jacking it up from as far outboard on the suspension as possible. If you jack it up directly under the spring seat you won't be able to make it happen.
Andy
If that doesn't work, you will need a spring compressor...
Old 11-07-2010, 04:58 PM
ericnova72's Avatar
More for Less Racer
Andy
Or some added weight, like a buddy to sit on the fender or bumper, or if the front sheetmetal is off a couple sandbags on the frame rail or weights from a weightlifting set. Normally it won't all just fit back together, especially if they are new springs or original springs that have been out for a period of time and have relaxed to be a bit longer.
The "jack as far outboard as possible" is spot-on, it adds leverage when you get it out there under the ball joint instead of under the spring seat area of the arm.
Old 11-07-2010, 09:14 PM
spring compressor?
Old 11-07-2010, 09:49 PM
aosborn's Avatar
Wiki Edits: 7
http://www.eastwood.com/coilspring-c...-internal.html
Spring compressor...
Old 11-08-2010, 12:23 PM
You used to be able to rent a spring compressor around here. Maybe you can where you are?
suspension for dummies rphillips Suspension - Brakes - Steering 4 07-23-2007 02:28 AM
who wants to build their own Mustang II front suspension? measurements inside !!! lowROLLERchevy Suspension - Brakes - Steering 1 09-07-2006 08:33 PM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
C5 Vette suspension into a fox body Mustang Beau Suspension - Brakes - Steering 2 02-13-2003 07:39 PM
