Suspension for Jaguar IRS for Kit
Andy, i found this thread and seeing what a great job you did on the Jag suspension, i thought i would ask for some help on my own challenge. Building a kit (Ferrari Daytona) on a custom chassis with jag V12 running gear (i.e. same set-up as the othe rcar on this thread). The axle weights are 1450lbs front and 1680lbs rears. The front suspension is adapted with a Spax coil over shock replacing the standard Jaguar one. The problem here is that i have moved and changed the engine so the front is now hugely over sprung and need a lighter spring, but not sure what strength. The problem with the rears are that they are the original Jaguar coil overs that are also way over sprung. I am sure this is not enough information to answer the question, but be grateful for your assistance to work it out. thanks
