update with geometry and weights
Andy, Here are the updates and full stats. The axle weights are 1450lbs front and 1380lbs rears. This is dry weight but i did add about 140lbs of ballast for driver. I did not add weight for a full tank (adds 100lbs to rear). The front suspension is an over sprung Spax coil over (due to replace of Jaguar V12 with SBC 383). The rears are that they are the original Jaguar coil overs that are also way over sprung. Thanks for your help.
attached are 2 charts of each suspension geometry and weights. i hope i capuitured everything required.
