Suspension options for 41 ford coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-14-2006, 09:39 PM
Good evening to all ! What are others experiences with their choice of suspension for early fords. I can go the obvious proven mustang II route ie. new cross member and new or used IFS . Alternately I have heard of using the suspension-steering unit from a mid 80's dodge diplomat ( the complete unit is removed from donor car by undoing 4 bolts and I have been told that it is easily adapted to the existing ford frame (after boxing it in). Has anyone with a 41 coupe done this ? The dodges were fairly heavy cars so this unit should be fairly robust although it may not look as 'pretty' as the mustang II. If a well cared for dodge could be located a person could even use the engine/tranny as well. Any thoughts would be much appreciated. Thanks !
Old 09-15-2006, 05:22 AM
BOBCRMAN@aol.com's Avatar
I have not done one. But, I saw one done with the MoPar clip and it sat way too high for my tastes. The Must II kits are about the easiest/best way to go. Use Granada rotors (three of my own cars, 46-48 coupes). Also did a 48 B-Coupe with a Camaro/Firebird front clip. Looked good. Exhaust was a headache and getting the correct "soft" springs.
'52 Ford steering options slantws Suspension - Brakes - Steering 11 10-11-2005 04:55 PM
ford 35 coupe gunnulf Hotrodding Basics 2 09-19-2005 04:27 PM
S-15 Jimmy suspension under 40 ford pkup? streetrodder31 Suspension - Brakes - Steering 2 08-28-2005 04:06 PM
Rightsizing rear end for 36 Ford Coupe... joeford Engine 2 06-02-2005 07:05 PM
33 Ford hiboy 3 window coupe gypsy Body - Exterior 2 03-11-2003 08:03 AM
