Suspension problem? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2013, 11:15 AM
Suspension problem?
Hi!
Im looking for 2" lowering springs for my 85 Ford ltd crown victoria stw.
Dont wat to cut off coils, and use old sptings.
Original spring are too soft for me.
Eny tips are welcomed.
Old 05-02-2013, 04:48 PM
LATECH's Avatar
Look for drop spindles .That would be a better way to approach the problem.
Fact is stranger than Fiction
Old 05-02-2013, 09:05 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Speedway motors or Stock car products for springs..we need the weight of the car on each axle to help with a setup..
Sam
Old 05-03-2013, 07:04 AM
I`ve read somwhere that Speedway Motors Tru-Coil 925# Front 1 Lowering Springs
Speedway Motors Tru-Coil 225# Rear 1 Lowering Springs where used on a 87 2 door crown victoria.
The whole care weight is 1850kg
Old 05-03-2013, 08:53 AM
454 Rattler's Avatar
NEVER SATISFIED !!
If you can't find the springs that will work, you could try cutting the coil springs because that makes them stiffer. I don't know just how much stiffer but, it might be worth a try.
454 RATTLER
mustang 2 suspension problem Atlas Suspension - Brakes - Steering 12 03-31-2013 09:20 AM
Suspension or frame problem? slik Suspension - Brakes - Steering 5 07-01-2009 08:50 AM
Steering/Suspension Problem reflog Suspension - Brakes - Steering 25 06-06-2008 02:42 PM
55 T-bird suspension problem Rick P. Suspension - Brakes - Steering 3 04-06-2008 12:53 AM
Help!!Front suspension problem 48aero Suspension - Brakes - Steering 3 08-01-2003 07:58 AM
