suspension question from a dummy.. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-24-2005, 10:12 PM
71_gto's Avatar
gggggrrrrrrrrrrrrr UGLY GOAT
im having trouble deciding on what to use for bracing.... i have a 71 gto. 455ho raIV. im pushing serious hp... now im seriously afraid that when i hit the gas hard im going to twist the body... im on a low budget.(spent it all on the motor) what can i do to make it stronger, cheap.. but quality... any tricks of the trade... i don't know how much it will withstand... don't know... any help appreciated... thanks
Old 03-24-2005, 10:41 PM
poncho62's Avatar
Wiki Edits: 5
Your full framed GTO will take a lot of power before twisting. If you are turning serious times, say 12 seconds, you will want to install a roll cage. If anchored properly, that in itself will help control twist.
Old 03-25-2005, 01:01 AM
71_gto's Avatar
great suggestion poncho... only one prob.... im trying to maintain the stock look of the vehicle... inside and out... when adding a cage... people say race car.. i want it to say old school..... with punch... lol... you rock poncho....when im lookin for an opinion, youre always one of the first..... you mean the world to a beggining rodder...
Old 03-25-2005, 06:46 AM
poncho62's Avatar
Wiki Edits: 5
That's just because I have a "Big Mouth"..................
Old 03-25-2005, 01:24 PM
Elevinpointsixtoone's Avatar
You may want to look into an add on frame cradle. Art Morrison in WA makes some nice ones but there are others on the market. Some are model specific and some are peice meal. You basically have to make it fit with your trani, drive shaft and exhaust which if already insalled may have to be modified (or not). No one will see it but if you crawl under your ride it will look pretty *****en! Most of them are round tube deals.
http://www.artmorrison.com/maxg.htm
Old 03-25-2005, 01:36 PM
astroracer's Avatar
What have you done in the traction department to harness that big power your new motor is putting out? Narrowed nine inch with a locker, 4.11 gears, a four link, coil overs and some big meaty slicks? You are saying the car is old school so I take it you have done none of the above... If the power can't get to the ground you are not going to twist anything. The car will probably smoke the rear tire for a week if you want it to but it isn't going to twist the frame unless you can do some axle snapping, front wheels hanging launches and that isn't going to happen with a stock rear suspension and skinny radials. Don't worry about it.
Mark
question for all you ford suspension guys Blag Suspension - Brakes - Steering 7 03-30-2005 12:59 AM
66 Impala suspension question black66 Suspension - Brakes - Steering 4 07-04-2004 09:42 PM
4-link suspension question brainsboy Suspension - Brakes - Steering 29 05-13-2004 07:39 AM
Ladder bar suspension install question glock35ipsc Suspension - Brakes - Steering 6 07-17-2003 11:46 AM
rear suspension question novass Suspension - Brakes - Steering 4 08-26-2002 10:09 PM
