suspension swap or frame swap?
hello i have a 42 chevy 2 door coupe. dont know if i should do frame swap
or could i get suspension parts for the front end like to get rid of the king pens. not sure where to start |
I would advise you to find a weld-in or bolt-in independent front suspension system and keep the stock frame intact. |
No frame swap..
![]() ![]() Get the right Mustang II front end for it...You won't be sorry in the long run..
thanks guys
chevy frame
Those old chevies had a "hat frame", formed sheet metal inverted U fastened to a bottom flat. It takes some carefull inspection to verify the condition, possibility of rusted thin spots, If the frame is in good shape you can buy the Bolt In kits for Mustang II front and various bolt in rear ends. Usually new rear springs or a pin relocator plate.
You could put a camero susp under it. It all ubolts from the camero frame. Then mount it on your. You nee a spacer between the sus. & your frame. I mount a couple of these & work fine.
camero sus
You can mount a camero sub frame under it. It all unbolt from the car. You need a spacer between the frame & the susp. You need the steering box to. I installed two of these They work out very nice. No hacking of your stock frame
![]() I weld all mine in,, No bolt's and no spacer's..
thank you guys
camero sus
well tryed to upload some picture today but couldn.t get it done. So i try again in a few dAYS
Here ya go, bolt in and made in the USA: SALE! TCI 37-48 Chevy Car Mustang II IFS Front Clip
| 1950 truck frame swap to 1980's chevy frame | 1950truck | Suspension - Brakes - Steering | 25 | 01-24-2013 06:13 PM |
| frame/suspension swap | azjune | General Rodding Tech | 2 | 03-31-2012 09:07 PM |
| suspension swap | 88chevy | Suspension - Brakes - Steering | 2 | 07-08-2006 11:46 PM |
| Suspension swap | raidmagic | Suspension - Brakes - Steering | 2 | 04-22-2006 12:39 AM |
| Suspension Swap | Cecil Stainback | Suspension - Brakes - Steering | 0 | 10-10-2003 09:07 AM |
