Suzuki Forenza Ignition Lock Stuck - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2014, 04:34 PM
On a 2007 Suzuki Forenza, I noted the occasional problem of the ignition lock cylinder barrel not moving out of the lock position. This was generally dismissed by twisting the steering wheel sideways to release pressure on stuck parts. Thing finally went from occasional to total lock-up.
Finally after releasing the tilt lever, loading the lock cylinder with WD40 and PIB , penetrating blaster fluid, pushing the key in and out to work the tumblers, etc, etc, and beating on the steering column plus banging the wheel up and down with the tilt lever released, I have decided that the beast is really stuck for good.
I do not have the procedure for removal of the lock barrel but it appears that may be necessary.
Any clues to something less than total surgery and a new lock barrel would be of interest. I have seen that others have had Suzuki Forenza ignition key troubles.
awbazar
Old 02-10-2014, 07:46 PM
dklong's Avatar
if its the same as a chev epica or suzuki verona you have to drop the steering colume and have the key in the run position and there should be a tab you have to push down on ( on the steering colume ) on the key tumbler housing, then pull the key housing out. then reinstall the same way,. the only problem that I had after I installed it , I did a PASS key relearn and it did'nt work did some reading , found out you had to use the dealer scan tool , for the relearn procedure, plus it had to be done with the second key. an additional $180 for the second key
Old 02-11-2014, 05:50 AM
Hello dklong,
Thank you for your comments. I got lucky on this one after spraying considerable WD40 and penetrating oil into the key hole and heating the assembly with a hot air gun for 10 minutes followed by 100 psi compressed air into the key hole to force the hot lube into every nook and cranny. I was ready to take a sledge hammer to it next!
This Forenza did not have an electronic key chip and was strictly a mechanical cylinder tumbler lock.
The obstacle with changing the lock cylinder was the fact that the steering wheel was locked and the access screws to the plastic covering over the steering column requires the ignition switch to be out of the lock position to turn the wheel out of the way to remove them without smashing or cutting off the outside covers. On top of that the key had to be in accessory position followed by pressing the detent on the cylinder to release in the lock barrel. I didn't have to do any of that...fortunately. The switch moves freely now. I did get that procedure from an Autozone online chat discussion. The fellow even emailed me the procedure. Autozone now has an email chat feature which provides installation and service advice. Not a bad concept!
I suspect it might be possible to release the steering column lock by actuating the unlatch feature which locks up the steering if one knew the right procedure to do that. I didn't have to go that far. Thank you.
Ignition Stuck; Key Won't Turn Apache_Boy Electrical 8 10-28-2009 06:13 PM
Ignition Lock Cylinder Alaskan Assassin General Rodding Tech 6 04-08-2009 07:25 PM
ignition lock cylinder help jesse01 Suspension - Brakes - Steering 7 03-08-2006 04:01 PM
ignition lock help needed stea Suspension - Brakes - Steering 1 04-16-2005 10:31 AM
key stuck in ignition WeberVette Electrical 3 12-10-2003 01:01 PM
