Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Swap
Thread: Swap
Old 11-15-2012, 05:55 PM
hcompton hcompton is offline
Old & Furious
The intake/wiring goes with the computer and the computer goes with the trans auto and std ecm are different in almost all cars some can be swapped with no issues. The std computer is usally a little hotter but i have no idea about the tbi.
That being said you should match up all the connectors to see if they are the same. One year diff can be totaly different but usally not. Best to compare the harness and see if they are the same. Wiring for a few new feature from one computer to another can usally be added in pretty easy. Just buy new pins from ebay or dealer and put them into the connector they are usally just blanked off in the main harness connector where it plugs into the computer. If that makes since.
Sorry not more help.
